Coolant leak
Rizzo
Just got done installing new injectors,coil pack and wires along with a new chip and got the car running as close to perfect as it'll probaly get.Went for test drive and pulled back in garage to adjust iaf and noticed a antifreeze leak.Cant exactly tell but seems to be water pump.Have coolant coming off crank pulley but cant see underside of pump.Has anyone had a pump go out this way?
When a water pump leaks it is common to leak from a weep hole on the bottom side; any car can do this. There is also a bypass hose on the top of the water pump to the intake manifold. It is S shaped. Feel around that for coolant as well before tackling a pump replacement.
