I went ahead & blocked the oil bypass in my 87GN's filter adapter, I just wanted some re-assurance that I did correctly.
I used a Dorman brand, cup-shaped plug # 555-009, 19/32" ouside diameter.
This fits INSIDE the existing little cup & bypass assembly, I did NOT attempt to remove the existing bypass.
Before installing the Dorman plug on the car, I practiced on spare filter adapter/ bypass assembly. The fit of the Dorman plug was snug, but it could be popped out without too much difficulty -- not good.
I then practiced (on the spare) staking the Dorman plug with a center punch, but staking it at the top of the Dorman plug in same fashion as the original bypass, doesn't really work -- the plug and surrounding area of the adapter get a little messed up.
I tried center punching the new Dorman plug near the BOTTOM of its SIDEWALLS (ie, at the bottom corner of the cup-shape) -- this "seemed" more secure (??).
Is this the right way to do it ??
The Dorman plug, if it came loose, is small enough to eventually float back up into the oil pump gears
with potentially catstrophic consequences. If it "can" happen, it probably will.
