Correction Window for PL with TT.61, making sure I'm correct
I have the TT 6.1 WB Chip
Looking at the attached image, the correction window for parameter 4 (Base WOT Fuel #130) is the window above it with #128 correct? As is parameter 8 (Base Mid Boost Fuel #111) the correction window is the window above it with # 134. THIS IS NOT MY LOG, just got the image off the web, but I want to make sure I'm looking at the right correction window to make the right adjustment. I drew in the line from what I believe is the correct parameters to correction windows, if it's not correct please feel free to change it.
There is only one correction factor. It is displayed in the BLM cell above the whole BLM grid.
Like this:
This box will display the normal low end current BLM when driving around, but when you get into boost, it will display the correction factor.
Eric
Ok, got it. Do the other grids above the adjustment parameters tell you anything?
The upper 8 cells are just the normal low end BLM's (fuel trim) that the computer uses to help maintain an A/F of 14.7 for driving around. Generally, we try to keep those in the 128 +/-10 area.
