couple snap shots of hit and idle opinions
vinis1987
Did all gaskets, rear main,headers,plugs,rebuilt ta49,alky single nozzle with new pump, 85 mm maf with trans, 43#inj ,front mount ic,power plate, heavy duty wastegate, new vacuum hoses,and all the main bas8c spring clean. I was tracking fb with pl but it was way off but 42 line off and rises 1 to 1. Vacuum at idle is 16. Tt 5.7 93 alky chip
Anybody got opinions on how it looks just from snap shots will load dat when i get home in a few days. Just wondering if looking good so far
WHats your alky controller set at? How old is your alky pump?
And 5175 rpm in 3rd gear and only 67 mph. Sum ting wong there
Alky set between 5 and 6.,pump is brand new.the 65 mph is actually top of second gear.somehow must of had it just right as it was shifting to third and letting off the throttle.this is the frame before but thank you for noticing that. Looking back it looks lik i may have some slipping. The other one is the top of 3rd. I am going to try to video one of the pulls. Really want to make sure there is nothing i am missing
