SignUp Now!I have been welding patch panels in the car so I think I should be able to weld it just fine, but I'm a little worried about if I blew a hole in that area lolNope, pretty common is all gbodies for our era. Get it welded up and install all the braces you can. Then it will still come back![]()
Ok I tried to weld it up and it seems like it has lead or some type of body solder that was used previously because it just melts and sizzles when I try to weld it, welder on lowest voltage and wire speed reduced to the point the wire just melts and pops.
You can see I did fix some of it, but I think If I keep trying it will only get worse, I might have to see if I can have a friend give me a hand, he was an autobody master tech, and has done restorations, so we will see.
