I too would like to have some sort of idea what these cranks can withstand. I know, it sounds cheap, but the turbo cranks are not easy to come by. I have 4 109 blocks sitting on the floor. One has a destroyed turbo crank. Cannot be turned. The other all have rolled fillets on the mains, but not the rods. They came from the junkyard like this. The motor in my car has a non turbo crank also. I did not know this when I bought the engine. It was out of a 1986 GN, and it had been freshened up before I bought it. I destroyed the bearings(they all just fell out when the caps were removed. I even melted a piston. A good 1/2 - 3/4 inch section, gone! But you know what, the crank is fine. Now that is 5 109 blocks, and no turbo cranks. That would be a ton of moeny, and alot of searching to find 5 cranks.
If the block is girdled, will this help the crank last longer? Just looking for alternatives.
How did I do that to the motor?? Well, I run some pretty good numbers (12.5@ 108) with 25# boost on 93 octane(alcoholic motor). I was tuning it, and pushing it to the edge, and then over the edge last year. This year the boost is lower, and I am seeing similar times with less traction. (Looking for 11's on whitewalls. I'll do it, even if it kills another motor!)
Brian
