I need some input on Precision Industries single disc lock up converters as I had a thrust bearing failure caused by one of their converters & would like to know of any others possible experience with this. The air gap between converter turned out to be only 040 thousands instead of the recommended .125 causing pressure against the crank. The converter was manufactured wrong & out of spec. Just want to make you people aware of this. Two other converter combinations were tried in this car with no issues & both had the required minimum distances. I am now about to find out how good the company stands behind their product.It gets shipped back today.Any B.S. or excuses I don't want to hear & wont be taken lightly. More on this story later depending on what develops from here.
