1987 GN, 40K miles. When I bought the car it would take 20 to 30 cranks before it would fire, after it was warmed up, 2-3 cranks and it would start. But if it sits for longer than an hour or so, again...20 cranks to get it going. Once it is started it runs great. It had everything original so I updated the chip, new injectors, plugs, wires, Walbro pump, hotwire kit, cam sensor, oil pressure sensor, crank sensor. It still takes 20-30 cranks to get it going when cold. But.....if I put the jumper on the hotwire kit to manually run the pump and then go to start...2-3 cranks and it fires right up. So, looks like it is not getting enough fuel. Under normal conditions (no jumper), when I turn the key, I can hear the pump prime for a few seconds then shut off. My mechanic checked the fuel pressure and it looked OK....any ideas ???
