He did this by over boring the cylinders of his 4.1 Liter stage 2 block to 4.061". You can't over bore a production block to this size. You must have a stage 2 block.How did you achieve 281 cu. in. ?
Claude.
SignUp Now!He did this by over boring the cylinders of his 4.1 Liter stage 2 block to 4.061". You can't over bore a production block to this size. You must have a stage 2 block.How did you achieve 281 cu. in. ?
Claude.
Yeah, or maybe a T/A block ? I already have a Stage 2 block (#153).He did this by over boring the cylinders of his 4.1 Liter stage 2 block to 4.061". You can't over bore a production block to this size. You must have a stage 2 block.
thanks,
Claude.![]()
I did notice that he was using 6.5" long rods.It is a stage block. Extra meat and a little extra deck height. That's how that long ass rod manage to BARELY fit with a stroker crank.
Don't bore it out big if you don't have to.
The deck height and long rod length is not the limiting factor on the stroke. Its more like the cam to connecting rod clearance.
In this case it was the limiting factor because you have to make room for rings. You can get away with encroaching on the oil ring with a support rail but the wrist pin can't get in the 2nd rings area.
Deck height,rod length, and stroke flat out tell you how much room you have for a ring pack. If there's no room, there's no room.
Never heard that but it works. I guess the engineering side of me just always wanted to just use pi * bore * stroke * cylinders. LolBore x bore x stroke x number of cylinder x .7854= CI of any engine.
Hehe. You're telling this to someone who has been running 6.5" rods with a 3.59" stroke for like 15 years. Two different sets of pistons. No ring problems. I know he doesn't have a unicorn either.
k
Maybe it's time you move to a Monte Carlo with a V8?Yeah, or maybe a T/A block ? I already have a Stage 2 block (#153).
thanks,
Claude.![]()
Yea I'm an idiot. What I get for late night texts. 2pi * r or d * pi is for circumference not area lmaoYou forgot to cut the bore in half and square it.
I'm with you though. It's easier for me to just do the standard math than remember constants and shortcuts.
I know this thread is a little old, but there’s room.In this case it was the limiting factor because you have to make room for rings. You can get away with encroaching on the oil ring with a support rail but the wrist pin can't get in the 2nd rings area.
