I have to take issue with the thought that your cam is a mismatch with your Champion heads. My combo is a bone stock long block with stock cam, TA49, Blues, Stock stretch, Alchy. With the stock heads my car would trap at 112-113 MPH at 22PSI. After adding Champion Irons with 100 lb springs, trap speed increased to 116-117 MPH. No other changes. None. My converter, by the way, is the modified stock diameter 2800 and I have the converter lock-up programmed into my TT chip at 70MPH. (just after the 2-3 shift).
I think if you up the boost to 22-23 PSI and start locking the converter in 3rd gear you should see 90+ MPH in the 1/8 and 113-114+ in the 1/4. And, you definitely need to start holding 2nd gear to 5500 or so. Good luck.
