bradofflorida
- Dec 12, 2002
I just put it on a new Scanmaster last night. Install was easy.
The knock readout seems to be working. I got it to read 2 degrees for a flash by hammering it from a roll, otherwise reads 0 at 20 lbs boost.
The O2 MV is all over the map. It reads like a random number generator at one second intervals: 250, 125, 770, 500, 800, 0, 50, etc. The car is running perfect, smooth idle & acceleration, with no hesitation.
Combo is stock long block, stock intercooler, stock turbo. Iceman intake, FP, regulator, hard pipe from filter to mass air, Armstrong chip, bleeder to adj the boost.
