Current lowering springs too low, which Viking Coilovers would work best?
JKGeorge1116
A bit of background. I have been building my Buick with the goal of being a decent all rounder with a large focus on improving the handling. Here are the mods that I have done suspension-wise.
  • SC&C Street-Comp Stage 2 Plus Upper Control Arms with greaseable Delrin bushings w low clearance Nascar ball joints
  • SC&C Front End Brace
  • UMI Rear Shock Tower Brace
  • GNX Rear Seat Brace
  • Viking non adjustable shocks
  • DSE 2 inch lowering springs
  • Hellwig Tubular Front Sway Bar
  • Hellwig Tubular Rear Sway Bar
  • Lee's Power Steering Box
  • 16" Enkei GNX style wheels
  • F Tire Size: 245/50/16
  • R Tire Size: 275/45/16
  • Factory Spindles
I recently installed an older Baer 12 inch brake kit that utilizes C4 calipers, 12 inch rotors, and Baer hubs. Now the car has always sat SUPER low with the DSE springs but with adding the hub, it pushes the wheels out just enough to where the tires are hitting the passenger side fender and very close to touching on the driver side. Based on pictures of other folks with 2 inch drop, it seems like my car sits significantly lower. I did buy the DSE springs when they first came out with products for the G-Body back in 2011 and they use a different part number now so not sure if that first batch dropped the car lower than advertised.
I am looking at getting a set of Vikings Double Adjustable Coil-over kit. It looks like Viking offers two versions on their website, and Gbodyparts seems to have a third.
  • Stock to 1.5" Drop: PN A224-450R
  • 1.5 to 3" Drop: PN A234-350R
  • 0-3": PN A204-450R (Gbodyparts)
Obviously the A204 version if it actually gives you 3 inch of range would be the best solution but wanted to see if anyone had any experience with that part number?
Otherwise For anyone running Viking coil-overs and has a similar brake setup, do you have any suggestions? 0-1.5 inches seems like it could be a bit too high but could be wrong. Ideally I'd like the car to be low but not at the expense of rubbing or bottoming out on bumps etc. Any feedback would be great.
It's currently too low for the suspension to actually work right, especially in the back.
Drop ranges listed on kits are approximate. They may or may not do that on your particular car.
I'm not familiar with the Viking "coiloverover" kits. I thought Viking just made shocks?
The Viking kits you shared put the entire spring load (and the entire weight of the car) directly onto the rubber bushing at the top of the shock up against the frame. That's not enough. That spot in the frame isn't strong enough. The bushings will fail quickly and fall out, the shock lower washer will hammer the frame, making a racket and destroying itself, the hole will eventually deform, and you're going to end up with a collapsed front end at some point. That would be bad.
If you do coilovers on the front, you have two choices to do it right:
1) The QA1 style kits that use a conical spring that sits in the factory frame pocket (works, but limited spring rate and height choices)
2) Going to a 2.5" cylindrical spring, but this requires adding an upper shock mount and measuring the car to get the right length shock for what you want (best, but it's a weld-in): Enhance Your Car Performance with G-Body Chicane Brackets
Since you've already gone through one suspension setup and aren't happy with it, it may save you a pile of trouble and money if you stop here and take few minutes to call UMI or Ridetech or QA1 and talk to one of their folks. They'll talk you through your goals and give you some measurements you can take and then translate that into a product set.
Stuff like this can be tricky. The kit can provide that kind of range, but to do that you're looking at a pretty long shock with a lot of travel. Depending on your car, you could end up bottoming that thing out and destroying it pretty quickly. Conversely, if you don't have enough shock travel, you'll yank the piston rod right out of the top of the unit. I know because I've done it. Just because it bolts in doesn't mean it'll work right. Measure five times, swipe credit card once.
That does look really low.
Some brake kits really push the wheels out as Turbo6inKY can attest.
Since DSE doesn’t offer 1” lowering springs, maybe some 1” lowering springs from UMI Performance would fit the bill.
The UMI springs are rated at 600 lb/ in front and 130 lb/ in rear.
The newer DSE springs at 575 lb/ in front and 125 lb/ in rear are really close to the UMI, but you might want to call DSE to verify your early ones.
I doubt you’d notice a difference.
If you really like the stance GNS Performance sells the GNX front wheelhouse extension kit (cut out pockets, not flares) to give the front wheels more room as another option.
Scroll down towards the bottom.
If you have your heart set on coilovers, UMI Performance sells Viking brand and are very knowledgeable about G-bodies.
They’re quite fun to talk to as well.
Thank you for the detailed response. I took your advice and spoke to the folks at QA1 and based on my application/use case, they recommended a Single Adjustable 450lb/in coil-over which is more or less the same price as the Viking DA ones.
This was a bit of an unexpected expense so I was planning on just doing the QA1s in the front for the time being and getting a set of UMI or BMR 1 inch/1.5inch lowering springs for the rear for the time being to get the rear of the car raised as well. Any thoughts on that setup?
Also, I was told to target around 200 lbs/inch of spring for the rears? I may be limited on spring rate options with the drop springs just based on a quick search. But I am assuming this would still be an improvement?
I would love to go the proper route and welding in the upper shock mounts and such but I got hit with a bunch of unexpected expenses at once and the car is currently stuck at the shop so I need to get it sorted as quickly/affordably as possible.
Than
Thanks for the response. So I did talk to GNS about the front wheelhouse extension, and that could potentially solve the rubbing issue but the car does sit way too low currently. So my goal is to try to correct that as well so that it's more drivable. And I was originally thinking about just getting another set of springs but with the variability between all these springs, and how much of a pain it is to do the front springs, I really didn't want to be in the situation where it still sits too low or end up sitting too high.
I run the QA1 setup in the front, but I swapped the shocks out for Viking Berzerkers. The QA1 shocks that came with the kit ended up being too short for my setup (I was running a tall lower ball joint) and I destroyed them. My fault for not measuring. So be sure to measure.
I have 210s in the rear, and I think they're really too stiff for street work. I think a 200 or a 190 for a street car would be more appropriate.
Good thing is the rears are a standard 2.5 diameter 11" spring, so they're cheap and easy to swap out. Get the 200s. If they're too much, it's like a $100 and maybe an hour to swap them out for a set of 190s.
As for single vs. double adjustable, I agree with the recommendation for the single adjustables. Unless you're racing and having to adjust for various different surfaces based on the track, you don't need the extra adjustment. Keep it simple.
get a set of rear gta rims
I was going to suggest the same thing. The front GTA wheels would probably work too, they’re sucked in pretty good however he has Enkei wheels which are a little different style.
You’re right, the rear GTA wheels would move them in more.
another option is what was used on the GNx ,
from rick hunt through gnsperformance .... Buick Regal Front Wheelhouse Extension Kit #20190RH
I know ride quality is subjunctive and we all have a different idea of the perfect stance.
I had some old ATR handling front springs I think were around the 550 lb/ in range. I’m going off wire dia. As they didn’t advertise the spring rate.
I had moog cargo coils (CC627) in the rear at 122 lbs/ in.
I had Bilstein shocks for reference and thought the rear was firm and nice, like a Z28 or Trans am.
I thought the front was a little floaty like it needed stiffer springs or shocks and have done some solocross Autocross events, but not as serious as Turbo6inKY.
I’m looking forward to the new UMI 1” lowering springs and Viking DA shocks, but have no input as of yet.
Maybe call DSE to see if a new set of their 2” lowering springs would solve things.
Maybe the first version had troubles sagging or something?
I got these Viking coil overs with help from Mike at Viking.
Double adjustable
Rear Viking, C211-T/14DP150C 14"
Compression 2, Rebound 8
Front Viking, A424HB-450R
Comp 10/Reb 4
I like the rake Dynoman, maybe 25.5" at the front fender flare and 27" at the rear?
I believe it was 26.5" front , back was 27+" . The car is facing down hill a little bit in the picture so it looks like more .
Thank you all for your responses. I went with those QA1 single adjustable coilovers just to have some leeway/adjustability with the ride height. I got a set of BMR springs for the rear. They were rated at 200 lbs/in vs some some of the other brands like UMI/DSE were in the low 100s range.
I may also pick up a set of used GTA wheels locally to solve the issue with the front wheels sticking out too far. The way to do it is to run the GTA rears in the front and the GTA fronts in the rear for the correct offset?
normally the gta rears mounted up front need a 3/16" spacer for front use to clear the outer tierod but the aftermarket disc hub kick the tire out so they should just bolt up
gta fronts mounted in rear will be bolt on depending on tire width but the dimpled gta with 255 drag radials ive seen them rub the frame (stock rear with drums) so a thin spacer may be needed
Quick update. We got the QA1s and the BMR springs installed. May try to use a spacer for the rear as it still sits a bit low. With the current wheels, there is enough clearance to where it doesn't hit the fender but still rubs a little bit on big bumps and hard braking. Needs an alignment but It has less negative camber at the current ride height, nowhere as extreme as before.
I did grab a set of used GTA rears locally and it does move the wheel in but its hitting the upper control arm and may hit the tie rods as well. Not sure if a 3/16 spacer and longer wheel studs would solve it or if I'd run into the same issue on the passenger side with it hitting the fender.
