I was wrong....the intercooler has fitting on the top and one on the bottom, with an allen head cap to drain the system. In this case, would I want to pump in from the top and return from the bottom, that way the pump doesn't have to try to push the water up through the IC? Also, should the pump be mounted close to the heat exchanger, close to the tank, close to the IC?
My initial plan was to mount the tank in the trunk, the pump along the passenger side frame rail, the heat exchanger up front by the radiator, and obviously, the IC in stock location. Finally, should I run this system with a 50/50 mix of distilled water and anit-freeze, or would adding some water wetter help....and should I use some sort of an in-line filter, in case I put ice in the system, I don't want to suck a chunk of ice through the pump and damage it.
Ok, now with the fittings on opposite sides of the tank.... you'll obviously be mounting the LIC in the stock IC location.... This means you will have one fitting facing the ground, and one facing the hood.
Being a biology major in college, i have been taking alot of chemistry labs. Long story short, we use condesor tubes to catch condensation from a boiling liquid. Water us pumped through the tube to cool the rising vapor out of the boiling vial.
You always want to have the flow of water through the LIC from bottom to top, against gravity. This will allow the IC to completely fill up with water until it has nowhere else to go besides out the top.
This is more reason now to have a dash mounted switch to operate the pump. You'll want to have that pump running atleast 10-15 seconds before you make a pass so that the LIC will fill up with flowing water. Also, after you make a pass, i would usually leave the pump running for a good 5-10 minutes to prevent heat soak.
It doesnt matter where you put the reservior. I would suggest having it in the truck for better weight distribution. As long as your pump is good enough to hold pressure with that much line while maintaining flow, you'll be fine. -10an is a good size, but running braided hoses for this is really unnessesary. I just used black rubber garden hose bought from home depot.
Make sure the tank is easily drainable. I had a release valve (a plumbing fitting) on the bottom of my tank, but my tank was mounted in the front of the car and i would just drain it into an oil pan. You'll want to have the drain at the lowest point in the system (obviously) so that all of the liquid drains out.
When you are at the track, you'll want to change the water between each runs with new fresh ice water. Distilled water is the BEST to use, as it has the highest specific heat out of any readily available substance. Dont use antifreeze at all, unless you are afraid of the water in the lines freezing (which shouldnt happen unless its below freezing temps outside).
The pump should be mounted underneath the reservior. Have a line coming from the bottom of the reservior into the inlet on the pump. This line should feed straight DOWN to the pump, so that the pump always has a supply of water.
Reservior->Pump->Heat exchanger->LIC->Reservior
Any questions let me know!
