I have an '87 Turbo that I've owned since April 15th. I drove it 1,000 miles back home and I've tinkered with it. That is my total experience with these cars. I've been trying to figure this out myself using these forums but I've got too many variables and I don't want to go replacing parts.
Here's the scenario. My car runs fairly well while it is still cold. I don't want to really test it while it is warming up because I've got enough problems already. Once it is fully warm and under WOT I get a cutting-out reaction. I do have a Turbo-Link now and I think I know why it is doing that. The speed on the Turbo-Link shows that it jumps from ~20mph to ~170mph and then back to ~30 and so on. I think it is "cutting out" because the computer is telling it to shutdown based on the governer. I did check the TPS and it is correct (.8 to 4.8 at WOT, if I remember the numbers right).
It has been having a problem lately of draining the battery too. I don't know if that is related. It also seems to run the radiator fan for WAY too long. It will run even if I just turn on the ignition and not even start the car. This varies though.
When I drove it back home it ran pretty good but that was just highway and I didn't want to press my luck by running it hard. I got about 22 mpg which seemed a little low but I was averaging 80+. The previous owner claimed to have replaced the plug wires and the vacuum hoses (presumably to fix this same problem that He didn't tell me about ) and those appear to be fine. Not totally sure about all of the vacuum hoses but would it run fine for 1,000 miles if they weren't? I had to adjust my TV cable and I still question my TCC, but that may be me just being paranoid from all I've read on these forums. Can I verify that info from my Turbo-Link v2.13?
Anyway, that's my story. From what I know the car is bone stock. I have all kinds of ideas but I don't want to just replace parts. I need to figure out a way to test what I already have on the car. My best tool is the Turbo-Link. I have a multimeter but I'm not sure what to test. If you have any suggestions, please try to keep them basic. I'm still just learning.....
Thanks,
Brad
Thanks,
Brad
