Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
SignUp Now!Decrease detonation issues Audie. More turbulance in the chamber which helps swirl and squish.
I have to disagree - what is the compression ratio with 20lbs of boost .?I have a set of heads on the bench and I am going to definetaly try this trick on them .![]()
on a dished piston like we run in our buicks i see no advantage
on a flat top piston and a head like shown where there is maybe only a few thousndths clearance between head and piston on what could be half of the piston surface it makes a lot of sense ...like running fuse to the center of the bomb
