Jan Larsson
- Nov 22, 2001
Building my engine and just want to double check the numbering of the cylinders so I get everything back in the right place ... See photo (front is to the right) and I got the following
6 4 2
-------Front
5 3 1
Billet center mains, ARP studs, stock crank cut 0.02, Eagle rods with ARP bolts, Ross Pistons +0.03, ported stock heads with larger valves, Comp Cam roller cam, roller lifters and Harland Sharp roller rockers .... and a few other bits
Clearences double checked and tripple checked and looks really good so far.
Blueprinted (block 100% square,) and rotating assembly balanced ....
6 4 2
-------Front
5 3 1
