TexasT
Texas, Where are you from
- Sep 10, 2002
Nope he died in 1980, so I doubt he knew what a turbo Buick was. Though he did wrench on a lot of stuff. I saw him and others unstuck tractor engines by removing the head and putting a 4x4 in the cylinder and beating on it with a sledge hammer and then soaking them with trans fluid and beating some more when I was a kid. He owned an Allis Chalmers dealer for years.In the hundreds of head gaskets I have replace blown like yours, I have never seen the other side gasket NOT damaged.
Do the smart thing and change the other gasket while you are 3/4ths of the way there.
In my opinion of what went wrong is that you were lean and too much timing, but also there was not enough fuel being supplied for it to go that lean. We never run that much timing even with a race engine?
The alky is there primarily for cooling in the combustion chamber, but there was not enough 100 gas to support the HP being developed.
So you need to evaluate fuel delivery which includes the pump, and sufficient power/voltage at the pump
The gurus have spoken swap the other one out. And I would do the timing set while I had it apart. I'm looking forward to the other side pix. I was under the impression that it is better to keep the factory "seal" but I guess I am mistaken.
