Oct 21, 2010 #1 S scot502 87 GN 49,000 MILES Joined Nov 2, 2008 Messages 116 JUST GOT A 87 TTOP GN AND THE DIGITAL DASH DOES NOT WORK WHAT SHOULD I CHECK. ALL FUSES GOOD UNDER DASH. THANKS FOR THE HELP.
Oct 24, 2010 #2 G GNVenom Well-Known Member Joined Jan 6, 2002 Messages 2,082 VERY common problem with the digital dash cars. First read this http://www.installationinstructions.com/FYI/digitaldash.pdf Then do this http://www.installationinstructions.com/FYI/digital_cluster_removal.pdf Then send it in for repair...
Nov 14, 2010 #3 S scot502 87 GN 49,000 MILES Joined Nov 2, 2008 Messages 116 Thanks for the help Always great help thanks very much. How do i check to see if dash is getting power.
Nov 14, 2010 #4 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,888 If you need to send it in for repair I would highly suggest you have John do the 199 mph upgrade as well. It really sucks to see the dash flashing 85mph. Bryan
