any reason why you are not using the coolant lines at the front and rear of the heads...from what i read on ls1tech--some think since the rear weren't piped on a lot of motors (or certain motors) that head gaskets went bad quicker ..
Should be really easy to achieve, I did a little over 800 to the wheels with a stock l33 5.3 with just a cam, and springs. Stock tty head bolts, E85 and no intercooler. I am thinking of changing the head bolts to studs before I head to the track this year. BTW 18 lbs boost on zo6 cam, untouched, unbolted 799 heads and a victor jr intake with twin 61 mm p-trim turbos.Sorry, found what I was looking for. These would be some impressive numbers with out an intercooler. Not doubting that it can be done, I truthfully have no idea. Good luck. I'm a fan.
That looks sick, awesome fab work!
Whats that whinning sound, Sounds awesomes, looks badass!!! Cant wait to see some more footage
haha I knew what it was... I was just messing around. Car is sick man.. When are the dyno pulls coming?It's the Weldon 2035 fuel pump delivering the cream corn to the 8 160 lb injectors.
How is your fuel system set up? I see the pump and the aluminum cell. Is it have the foam? What size line are you running to and from the pump and filter? I'm looking to do the same set up in a gn. Hard to find other people running a cell and corn. lol
Where did you get a cell with -10 feed lines? What type of filter? Thanks for the info! Amazing build.
