BMF_Racing
ONE B.M.F.
- Apr 26, 2006
Well just did the first tuning session after installing the DBB 6776, 62mm hemco w/62mm TB and big FMIC. The engine is stock unopened, other than valve springs.(may be another reason for overboost with small head/intake) I was very happy with everything but cant contol the boost from creeping.
The boost is 21 to 22psi in 1st & 2nd and in 3rd it creeps higher and higher (boost gauge is only 20 psi for now). The car has THDP with 1.5" puck. Before the install, I did machine and ported the a/r housing's wastegate hole out to 1.375" to try to help with boost creep that I read about on the forums. I do have the MAFT Pro on the car with Boost Controler but not hooked up, just a vaccum line to the WGA with no preload on the WG arm (arm is loose and can giggle with your fingers). I can loosen it more but it just causes lots of turbo lag and still eventually gets over 20 psi in 3rd. The WGA is the low pressure one from Full Throttle. Is there anyway to control the boost to lower it in 3rd?
I would like to run arount 19 to 20 in all gears, but don't know if I need to take the A/R off and machine it bigger and get a different puck for the THDP to accomplish that or if theres something else I can do to help?
