dead battery
kh440
Jo Bu needs a refill!
Something is killing my battery, leave it hooked up and by next morning it is dead as a hammer. tested battery multiple times when fully charged and it checks fine, with vehicle running voltage at battery is 14 volts, and did the multimeter test, showed a draw of 1.4-1.7 amps. Pulled every fuse one at a time and reading never went beyond that range...any ideas?:eek:
replaced both door jamb switches, fuses checked ok and trunk light inoperative (haven't gotten around to replacing bulb) also ran test with headlight and i/p switches removed and results the same....
