UnderdogGN
- Oct 18, 2004
1987 Rosewood T-type Limited T-top Vin # 1g4gm1179hp413537
4k Firm--car Is Worth More Parted Out But Its Too Nice To Part!
Body:
Rust On Lower Quarters Behind The Tires, Surface Rust On Botooms Of Inside Doors, Few Bubbles On The Decklid, Paint Looks Good From 20'. Hood Is From A Hot Air Car And Color Does Not Match,all Exterior Trim Is There And Decent. Scratches And Door Dings Are Present.
Interior:
Bucket Seats/ Console And A Column Shift,non Power Pillow Top Leather Seats Saddle In Color, Fronts Need Recovered, Rear Is Good, Carpet Is Good, Headliner Is New In The Trunk Needing Installed, Concert Sound Radio Works But Has One Blown Front Speaker, Door Panels Are 5 Out Of 10 Condition. T-tops In Good Shape Probably Couls Use Seals And Trim On The Body.power Windows Work, Locks Need Work.
Motor:
All Stock Except Adjustable Wastegate Actuator, Runs But Has Stumble In On Acceleration And A Small Miss @ Idle, New Battery, Leaks Some Oil (typical Turbo Buick)
missing all caps
Rear End Is A Posi
Trans= Stock And Shifts
Body:
Interior:
Motor:
missing all caps
Rear End Is A Posi
