TURBOPOWERED68
David
- Jan 31, 2006
cool stuff dude.
love the work and details
SignUp Now!The stainless downpipe sitting next to the bumper is RJC's 3" with internal WG.Nice build, what downpipe is that
They're GN1's with the $750 CNC port option. I got the $400 CNC port option for the Champion intake as well.let us know what it do when u get it together .... who did your heads ?
The feed line is all -6 AN braided line and fittings. The return line will be AN fittings as well, except for where it attaches to the frame. Since there is no AN-to-saginaw adapter for that, I may just try using double hose clamps. It is a very low pressure line so it's probably safe. If that doesn't work i will cut off the saginaw end and use a compression type fitting, similar to the way oil pressure fittings are.What did you decide to do with the lines from the frame to rails?
Chris
