WE2Regal
- Feb 22, 2003
Most of the "off the shelf" NA 231 replacement pistons are listed as about 8:1 compression and are supposed to be stock replacements for 79-87 engines. There was a change in deck height in 1986 with the 109 block. Wouldn't there be a difference in compression because of different deck heights using the same piston? Ruggles said the flat top 3.0 piston made "12:1 compression in an otherwise stock 3.8." At the time that book was written, I'm guessing he was referring to using a 79-85 engine block. Would flat top 3.0 pistons make more compression in a 109 block? Is the compression ratio affected at all by the year of the engine block when using off the shelf pistons?
