redhotrod
Turbo Happy
- Nov 19, 2002
Hey all,
I need some help with a problem, just rebuilt my 700 in my pickup truck. I added a .500 boost valve, corvette servo, kevlar band, and a transgo 700 jr shift kit.
All gears work fine but my reverse seems like it is low on pressure. I dropped the pan and checked the reverse boost valve and pressure regulator to be sure they weren't sticking. Also checked the converter valve to see it that was sticking. And I also checked the accumulator overrun valve too. Nothing seemed sticky.
When I assembled everything, I pressure checked everything according to the atsg manual. Only thing that really leaked air was when air checking the overrun port on the input shaft it blew air out of the checkball near where the reverse input drum meets the input drum.
Something else I'm thinking is if I'm using a .500 boost valve, do I need to upsize the reverse boost valve?
I was going to go get some hydraulic hose to rig up a 300psi gauge to check pressure but everyone is closed today do to memorial day. I'll try and check pressures tomorrow.
