GNONYX
- Oct 16, 2009
DO YOU THINK IT MATTER IF I DEPRESSURIZE POWERMASTER SYSTEM IF THE CAR IS NOT IN USE AFTER TWO WEEKS?
THE REASON WHY I'M ASKING, I JUST FINISHED TROUBLESHOOTING THE INTERMITTENT BRAKE LIGHT COMING ON AS I PRESS THE BRAKE.
AFTER DOING SOME READING RESEARCH, I HOOK UP THE KENT-MOORE J-35126 TURBO PRESSURE TEST GAUGE AND SAW THE ACCUMULATOR WAS LOSING PRESSURE, AND THE PUMP WAS CYCLING TOO SOON. I REPLACED THE ACCUMULATOR, RECHECKED, AND THE PRESSURE MAINTAIN 600psi FOR 30 MINUTES BEFORE I SHUT EVERYTHING DOWN. THANKS FOR ANY INPUT
