Turbo6Smackdown
- Dec 31, 2005
Ok, who here runs an eaton detroit locker? Do you notice any improvement? And who has the best prices on this unit?
Unpredictable? In what way? How so?
I could care less about cornering. All I want, is an absolute guarantee, that both of my wheels are locked in a perfectly even 50/50 forward position, at a street light, with about a 10 psi launch. I want both wheels spinning forward regardless. and I don't do donuts either, so that doesnt apply.
I have installed a number of Detroits in off road vehicles and my experience has been as stated above except ;you must be COASTING around a corner to disengage...power on ,its locked up. They are noisy at times but have enough slack to let you drive at hwy speeds OK.Drive to reverse slack is annoying but normal. VERY sensitive to tire diameters....tires must roll out the same or it will pull toward side of smaller tire under power...same with spool.Most friendly street unit is Eaton clutch type posi unit.Equal tire pressure and equal traction(not in dirt with one tire) will provide very satisfactory results 99%of the time.You might have to stagger tire pressures if the car transfers weight heavy to one side.
coasting around a corner? No problem. slack at highway speeds? I don't get it. why would it not like highways?
And the eaton clutches. (isn't that what we have from the factory?) I was talkin to the eaton rep at the autorama this weekend, and he said sometimes, if you're getting any slip, the clutch type units will start to transfer torque to a wheel. Is this true? I want no transfer. I want both wheels spinning forward regardless of what's goin on as far as traction. Spools are not an option. This is a street car ONLY.
With the amount of vht on the tracks, I could run factory radials on a pegleg and hook. That doesn't take any talent. Traction on the street, with a stock turbo and a 2800 rpm converter does however.I need all the help I can get.
Noise isn't a problem. Winning every race I get into is my only focus.
I thought eaton was the maker of the detroit locker.
