excobraguy
- Feb 25, 2007
87 GN with 200-4R. I just changed the stall converter from a 2800 to a Pro Torque 3200-3500 stall. I installed a new filter, 3 qts. of Dexron/Merc III and 6 or 7 qts of regular hydraulic tractor fluid, not the Mobil 424 (couldn't find it!).
So theres the setup, now the problem definition. The car with the 2800 stall had no shifting problems, all gears ran out nice and it shifted fine, but overderive did not work. It originally had regular tranny fluid. Now with the Pro Torque converter under WOT it shifts to 2nd and then to 3rd way too fast, the rpms are around 3000 on the shifts. It does however, go into overdrive where the 2800 didn't. Also, when around 35 mph and in second gear, I used to be able to hit WOT and it would downshift, now there's nothing...it just lugs until it shifts to third. Could the extra thickness of the tractor fluid be causing it to shift too early? It seemed a lot thicker than the Dexron III. The hydraulic fluid is Allison C4 rated and I read somewhere that this was OK for our trannys. I plan on changing the fluid this evening when I get home from work back to straight Dexron III. Does anyone have any other inputs based on my description? Is it the new converter? Are there computer settings that need updated with a converter swap? Oh, I also reset the TV cable thinking this might help, it didn't.
Thanks guys.
Thanks guys.
