SignUp Now!YesDoes anyone know if you can have Diamond make a piston with a custom dish size? Looking for a smaller dish for a little higher compression.
Haha! Ok thanks!It's not about opinion. it's about simple math. What is the deck height and connecting rod center to center distance?
Nice! I see you slept in today!Hey Vern, to get the compression ratio up over 9:1 with your parts we will need a dish volume around -20 or -22cc
http://www.csgnetwork.com/compcalc.html
Sounds good to me! I'll get them ordered tomorrow!Let's go for -20cc. It'll be right at 9.5:1 and still have some deck height available.
What are your goals for this motor, and what cam are you going with?Steve, we think alike.
I have one going together for a friend with that same Static.
Testing the waters!
6766 from Bison and
Ported Irons
Turbo Tweak chip
on the Corn.
That will be interesting, especially if the rest of the engine build, trans and car weight are close.The owner wants to see a 10.50. Not a huge fan of high boost needles. I'm going to use an off the shelf 212/212 hyd. roller. I know it can be done with less, but we are trying this to see how things work out. I like Diamonds but my builder said we will use JE slugs for my two builds he is doing for me.
The second is an iron head stroker that will use a 212/212 to see how it compares to a 234ci with the same basic combo.
I have a similar goal for mine. I was going to go JE, but was sold on the Diamonds. I'll have ported irons, with a 210/215 roller cam, and a 6266 turbo. PTC converter 28" tall tires also. E85 too... Compression ratio should be 9.5:1The owner wants to see a 10.50. Not a huge fan of high boost needles. I'm going to use an off the shelf 212/212 hyd. roller. I know it can be done with less, but we are trying this to see how things work out. I like Diamonds but my builder said we will use JE slugs for my two builds he is doing for me.
Honestly I didn't make the decision on my own, but it's a good match with the newer style cea wheels, and the bigger turbine wheel of the turbo I'm using. Mike from Full Throttle also confirmed that they are a good match.Can I ask why you are using that cam and not a 210/210, 212/212, or a 214/214? I'm just curious to see what helped you decide.
