Turboholic87
You feeling lucky punk!
- Apr 22, 2007
Before taking my block to the machinist I had the main cap mating surfaces cut .004" for a line hone and had fitted the girdle to 3-4 thousands pan rail clearence (preload) with the main studs tightened down. Was getting ready to assemble my engine this weekend and noticed that when I put the girdle on the block and tightened the studs all the pan rail clearence was gone. Long story short the machinist took everything apart, cut the caps again without checking first, and line honed with the girdle now having about 2-3 thousands negative preload. Called him up and he reassured me that everything would be OK and he had another motor in the shop machined with no girdle clearence like this making 750hp no problems. The sad part is he specializes in Buick engines around the Chicagoland area. I think this guy is blowing smoke up my a$$
, what do you guys think I should do? He said just shim it back up if I'm nervous about not having clearence but then whats the point of doing the line hone.
