It is a 2 pulse per speedo cable revolution? Maybe it could be used to calculate and display drive shaft rpm directly. The the only correction would be for the speedometer gearing which is easy to determine. It may be a nice if room existed to add the feature. Trying to figure out exactly how to determine the correction factor is like going on an Easter egg hunt. At the end of the day I think the calculated numbers should match what Dave experimentally determined, even though they are close now they should agree. I guess the other option to help nail it down would be if you could pull out the factors that the ECM uses to calculate the MPH. Knowing the exact tire height and any other assumptions to dial in the correction factor may get it right on.
P.S. - The MAFT Pro is still a killer piece of gear, I am using in Translator VE mode, and it makes it real nice to integrate the alky injection. I needed more fuel and had an old Caspers 7th shooter(old school, many cringe at the thought) from the 90s sitting around so I tried it out, and also able to use the VE map to integrate that. I have had a lot of fun with the MAFT Pro, well worth the purchase. Thanks for the great products.
