JDSfastGN Well-Known Member Joined Jun 16, 2001 Aug 8, 2010 #21 trans damm said: About what RWHP does a STOCK GN make? Click to expand... 190-210 rwhp/270-290 trq bone stock is what Ive seen reported
salvageV6 Daily Driver Joined May 25, 2001 Aug 9, 2010 #22 I'd want to see 240/250 out of a good running stocker. :smile: I don't think the stock intercooler is helping the OP's car either. Time for a stretch stocker with big neck or one of the newer aftermarket stock locations. I'd address the fueling issue first for sure.
S stk6bngr Member Joined Dec 24, 2004 Aug 10, 2010 #23 salvageV6 said: I don't think the stock intercooler is helping the OP's car either. Time for a stretch stocker with big neck or one of the newer aftermarket stock locations. I'd address the fueling issue first for sure. Click to expand... Yeah Ive got a walbro pump with a hot wire so I'm thinking im gonna try and see if the fuel filter is the issue first. I do plan on getting either an rjc front mount or a cottons havent decided on which one to go with
jasjamz THS Racer Joined Sep 30, 2004 Aug 10, 2010 #24 Isn't it hot there a lot? You may want to consider the PTE stock location unit.
S SIXBANGR mean old man Joined May 25, 2001 Aug 10, 2010 #25 jasjamz said: Isn't it hot there a lot? You may want to consider the PTE stock location unit. Click to expand... I agree, hot or not, best one i ever ran.
8 87GN_70GS Active Member Joined May 28, 2001 Aug 10, 2010 #26 Somethings screwy with the fuel supply. A walbro 340 should fall short of supplying 60 #'s injectors at 100 % dc by only a few (maybe 4 or 5) psi, not 20+ psi.
