So i dynoed my car on thursday the temp in the shop was 97.8 degrees 1 percent humidity.
my car dynoed at 391 hp with 458 ft lbs of torque at 19.8 psi 21 degrees of timing on 100 octane.
my set up is pt54 with .63 housing. 3'' thdp, brian h. tranny full billet rollerized trans brake with a 2800 stall 9.5 inch ptc converter from dusty, walbro fuel pump, 3 inch ss atr dual exhuast, hot wire kit, ported stock iron heads, 60lb mototron inj. with tt chip.
the dyno graph shows i was running way to lean up top 14.3 to 1 so i tried to add 10% still to lean. 3rd pull i added 20% a/f didnt change. bumped up fuel pressure and it was good till about 5500 rpm and the fuel pressure dropped about 20 psi....
do i need to get a bigger fuel supply line?
