Scott89TTA
- Jul 12, 2005
Drove my car to work last Monday & Tuesday after sitting for about a month. The car ran great especially withe the upper 50's and low 60's. On the way home Tuesday a couple miles from my house the car bucked/hesitated a couple times, almost seemed like the trans was acting up. I got it home and it started doing it a lot on my street plus I heard a lot of racket under the hood. Pulled in my drive way and shut it off, opened the hood and found my belt had peeled off one or two of the ribs and was whipping the broken piece around. Once i cut off the bad loose and listened to the motor and trans all was quiet. I picked up a new belt Friday and installed it yesterday...started the car and all seemed good. This morning I took the car out to a Sunday morning Cruise hangout that is about 28 miles away. About half way there at around 55 mph it starts bucking again almost like it is slipping in and out of gear and then I hear a bunch of racket again. I pull over and pop the hood...my brand new belt peeled off a rib or two again. I cut off the loose piece, turned around and headed back home. It ran OK for a couple miles then started bucking again but this time if backfired through the exhaust a few times. I pulled over and shut it off for about 15 minutes then started it back up and headed home. It ran fine the rest of the way home...~20 miles or so? So what is going on to cause my belt to shred? The backfire makes me think the ignition cut out possibly by the coil pack failing or the battery is shorting out and going bad? But what would lock up and cause the belt to shread...or can the bucking of the engine misfiring and cutting out cause the belt to jerk and break? The belt before this one was about 5 or 6 years old with maybe 8-10K miles, the alternator and battery are both fairly new. Voltage is a steady 13-14 volts and the alternator is nice and quiet. I had a MAF go bad years ago and the car just cut in and out but never backfired...replaced MAF with LT1 and Translator. Any ideas?
Thanks,
Scott
Thanks,
Scott
