Whereabouts in TX?
Tips for passing emissions test in the Houston area at least:
Stock chip if possible, or have an emissions chip burned for cars with big injectors
~38 lbs fuel pressure line off, lower the boost to 10psi to keep things safe!!!
Bottle of Techron additive & a gallon of Xylene 2 tankfulls BEFORE getting the test
NEW spark plugs & make sure the wires are in good shape, actually a general tune-up is a good idea & needed yearly anyways
Make sure the engine is nice & warm before going to the emissions station. Take the long route & run the A/C on full blast, the warmer the engine is the cleaner it runs!
I had my car within ~10 counts of passing on the Hydrocarbon specs following these "tips".... with NO catalytic converter on the car, a chip that needed some serious tweaking & only ~15 miles on the newly rebuilt engine!!!
Super unleaded should work just fine, keep in mind that regular unleaded may light off too soon under load (depends on the test they use in your area) which is definately a BAD thing! ie Detonation, increased NOX on the test, etc.....
Doug C.
