Dominator vs Fast vs GNECU
yarbeau
Darth Vader
I've been scouring the net to find a breakdown of pros/cons of each system. Hoping someone can point me in the direction or even break it down. Not building a racecar just want the safety and reliability of a new ECU. A little background on the car.
Stock 87 GN. Wiring harness seems to be in rougher shape so I may be looking at replacing it entirely with the new ECU. New dash system would be a nice add on as I am not a fan of gauge pods littered around the interior. Goals are reliable 9-10 second street car on pump gas and meth that i can hop in and never worry how its going to react. $$$ is of course a factor, i know nothing is cheap but if one system is 2k more but offers the value I'm only doing this once. I am not a tuner so the less I have to tinker with on a computer the better.
Pulling the motor this week to send in to have it machined and long block assembled. This isnt going to be a quick turn around I am in no rush just want to make the best choice.
That factor is the main one.
These computer systems are alot and depending on how many sensors and what you wish to look at costs will jump alot.
The systems are only as good as the tuner period.
All of them including a stock ecm are fast enough to reach your speed goals.
It's how much you have to spend and who tunes and supports the computer setup
If:
a) you don't have some one to tune and you don't want to do it yourself
b) money is an issue
c) running gas and meth (not e85)
Get a new stock harness from Caspers Electronics and an appropriate chip from TurboTweak and be done with it.
I have had an ECUGN and currently run a Holley Dominator with a 12.3" pro dash. I love the Holley system and the dash lets me not have any other gauge pods and clutter which really cleans up the interior.
The ECUGN is more than capable but for me the software leaves a bit to be desired. In my opinion the Holley software is easier to use but you have to build some of the safeties that are already in the ECUGN yourself (more tinkering). If you want to use
Cost wise it is not cheap either way (prices are approximate and probably have gone up).
TurboTweak chip $125
Caspers Harness $1250
ECUGN $2100
DD-EFI Dash $700
Caspers Harness w/ECUGN addons $1400
If you want coil-near-plug add $325 + the cost of coils
Holley HP Kit (from Cruz; includes harness, coils, etc) $3500
Holley 12.3 Pro Dash $2000
3d printed dash/bezel/wiring $600
Prices just go up from there. I went with the Dominator over the HP due to wanting the trans controller and not being limited to 4 input/4 output. The ECUGN has more I/O than the HP but less than the Dominator.
If:
ECUGN $2100
DD-EFI Dash $700
Thanks so much for the breakdown. My hands were leaning to the Ecugn simply because of cost and this not being a race car/needing traction control/transmission access.
What was so negative about the ecugn that’s caused you to switch to Holley? In my situation I wouldn’t be looking at playing with the software and would leave it how TT sets it up for me. Is that reasonable?
Cheers!
Cheers!
As stupid as it sound the main reason I switched was I wanted the 12.3 dash, separate coils and the better (in my opinion) software. I also like how Holly handles the boost control and the advanced tables for tweaking stuff. I was also able to get a custom harness from Cruz to put the ecu under the passenger seat with the powermaster stuff deleted, boost solenoid wiring and flex fuel sensor already in place. Caspers does not do custom.
I have nothing bad to say about the ECUGN; it does the job really well and can use the stock harness. If you have and doubts about your wiring harness replace it. Mine was bad.
TT will set it up with a base tune but it can still be refined further. You can can integrate the alky system in with it and get rid of the extra box but that is more tweaking.
If you have an ECUGN shop/tuner nearby then that’s the way to go. Same for the Holley. First and foremost you want an experienced turbo buick expert, then go with whichever system they’re recommending. Where are you located?
I am in Edmonton/Canada I'll do some digging. Great advice.
I bought the Dominator because I swapped to a 4L80e and needed transmission control. I also bought it so I can control 2 injector sets and get rid of my old way of doing it. I bought the 12.3" Pro Dash to get rid of any external gauges and to replace my boost controller. Those things in itself is icing on the cake. The software is easy to use.
Holley's are used everywhere in all kinds of engine combinations from slower cars to all out full-tilt race and drag-n-drive cars. The info for just about any engine combination is easy to find. Granted, there's not a lot of info about a Holley on a Turbo Buick engine that's publicly available. If you're willing to learn about using the Holley, you can find more info about it than on this site. For example, take a look at the Performance ECU Forum on this site. The first 10 threads date back to Jan of this year. There's hardly anyone on TB.com asking questions about any ECU. Social media has killed the days where you can easily find answers to questions from 5-10 years ago.
Also, if you're always relying on a "tuner" and paying them money each time, consider that a payment plan with any ECU.
I started because I needing a wiring harness. Probably the hardest part is setting the Holley up the ignition system.
With Holley you have 4 different options.
1. OE
2. truck coil
3. LS coil ( I chose this)
4 Holley smart coil
then there 2 (that I know)ways to set cam and crank signal strategy . may be 3 what I did worked for me using LS coil
I will gladly share any thing on my laptop to any body I have no secrets. I don't think I have any secrets from any body that has helped me along the way.
It was a very hard choice, I have been a with Eric and Bob from the beginning. It was not support from any one vender but software, I downloaded both Holley and a MegaSquart and the Holley was easier for me.
after that I chose a vender I have been with for a long time. Caspers and Fullthrottle has given me 5 star support and you have Cruz that has been doing Holley for a long time that has 5 star reviews from loyal customers.
If you chose ECUGN or Holley you will get excellent Suport for the Buick venders snd community.
