drag radials
chops
Am looking to buy a set of mt 275/ 60/15 drag rads for my 87 turbo t will they fit with out any problems any info would help thanks tommy
They should fit mounted on 15"x8" wheels with a rear spacing of 3.5". Also, you might have to roll the fender lips which is no big deal...
Claude. :smile:
Claude. :smile:
I am running 15x8" with 4.5" back space useing 5/16 spacers to keep from rubbing the frame. My fender lips are not rolled.
tires
A 15x8 with a 4" backspacing is the best fit.3.5 WILL HIT THE OUTSIDE LIP AND THE 4.5 WILL HIT THE FRAME.I had all three on my car but i no all cars are different so thats all i can tell you.Good luck:biggrin:
I had MT drag radials on my factory (15x7) 87 GN wheels with no issues. I had aluminum drums on there. They were 275/50/15's (26"tall) which are a little wider than the 275/60/15's (28" tall)
You should be fine
I had mine on 15x8 with 4" bs and rolled lips. Just barely clears the frame.
with factory steel wheels, no rolled lips or anything. It was a very tight fit, but it didnt rub at all with the aluminum drums.
Another guy I know used a washer on each wheel stud to clear, and still no rolled lip.
