Hello everybody;
I need some assistance diagnosing a problem. Car starts, and idles fine. Will drive ok, but when I try to accelerate car, no power! Boost
pressure will rise but it stays at same speed, and if you use accelerator
softly it will go, but as soon as you press down, nothing. It's a stock
86 GN no mods. Earlier this year I replaced the ignition module, and coilpack.
I have 38 PSI static fuel pressure at rail, and 14 volts at alternator at idle.
I re-set IAC and TPS. TPS reading .43 volts and 4.6 volts WOT with key
on not running. Replaced fuel filter and new plugs and wires. I do not have
a scan tool to monitor engine while running, but no major problems so far.
No malfunction codes and ECM has a stock burned chip from Turbo-Tweak.
It had a Hypertech chip which I placed in a ECM I purchased at a reputable
salvage yard. I swithed out ECM's and no difference. I'm running out of
ideas and any suggestion will be GREATLY appreciated! Also I have boost
lines hooked up correctly with restriction in T hose going to the compressor
housing unit.
housing unit.
