I purchased a used Directscan. Dowloaded the program from the Chu website for 1.52, as the seller sent me a blank disk. I am also using DOSBOX, which Chu recommends. Plugged it into my ecm on my 87 GN. I get an error message- Directscan Hardware Not Found. Could the cable from the laptop to the black box be bad, or the direct scan black box be bad? I also get the same error code if I just run the program in my kitchen with the black box hooked up to it (but not hooked up to my ecm via the ribbon cable). My programmer friend was not sure if the program automatically reads the correct parellel port, so he will check it for me next week. Could my laptop not be configured correctly to read the black box? I guess this is what happens when you buy used stuff. Thanks.
