SignUp Now!bison said:If you have over 400hp its definitely necessary.
If you were building and selling transmissions would you guarantee that there wont be a direct failure without dual feeding in a high hp application? I have seen them last a long time in 125mph cars but they usually dont forever. Once its dual fed and forward drum has been replaced with a a billet shaft its indestructable from what ive seen. Other parts start breaking from the violent apply of direct.V6RACER said:Never had a problem years ago with well over 500 hp and no dual feed.Yes, it is a good thing to dual feed the direct, but it isn't the end all for direct clutch failures.
Its free to perform it but i wouldnt do it without a billet forward shaft.jakeshoe said:Considering it is a FREE mod, and commonly accepted to be standard fare for building Th350's and 400's, there is really no reason not to do it IMO.
Sure,
we can jack the line up to 300 lbs and make the clutches live, but why stress the pump and sealing rings?
chris718 said:recent testing has shown that when dual feeding with our methods and ALL OF THE PARTS INCLUDED in the recalibration kit(2 holes for the 3rd apply already pre drilled to .140") that drilling of the 3rd accumulator hole is not necessary.it can be left stock.
Mine wouldnt last either.JDSfastGN said:I've got two trannys running this setup(CK shift kit and dual fed) and am very pleased. Both are not overly harsh or snappy at part throttle cruising, but at WOT they a very positive shift that really snap. Neither has a flair or bindup. I definitly am a believer in dual feeding as my directs would never last before I did this mod.
