EightSecV6
MDBL
- Jul 18, 2001
Originally posted by summit
Wonder what pump I have? A while back I broke the cam sensor gear with a timing chain issue and had to replace the driven gear in the oil pump. I had to take a high volume big block gear and press it onto a v-6 pump driveshaft. The oil pump I have has the inlet and pressure lines coming out of the side. I have also seen another type of pump where the lines exit the bottom. I remember having three gears laid side by side comparing the heights. A stock V-6, high volume V-6, and the high volume v-8. Each gear was about 1/4 taller than the next. The high volume V-8 shaft was about 2 inches longer than the v-6 ones, therefore we had to swap out the shaft. Any ideas or am I crazy?
Greg Kring
You CAN use a high vol cover with the Dut. pump IF you run the high vol gears for a big block, standard procedure is a stock front cover and Dut. pump with high vol gears for a V6.
