Dyno questions
vince87t
I had my mostly stock 12 sec recipe car dynoed today and it would not exceed 15 PSI Boost. I drove it home and walla... 19 lbs was there. Any ideas why? The numbers were as follows: 1st run 298 HP and 398 lb/ft, 2nd run 302 HP and 399 lb/ft at the wheels (at 15 PSI). The dyno guy said it might be that not enough "load" was on the motor to produce peak boost. I stuck around and checked out a 540 HP and 700 lb/ft twin turbo LS1 run at the exact boost it was set at (8 PSI). Any ideas? Thanks, Vince
Your chip may allow higher than 15 psi in first or second but not in 3rd. What do you use for boost control and what chip are you using?
