heads are stock, totally stock 85k motor, walbro 340m ( 255 ), actually only about 105 oct as there was 93 in the tank bout 5/6 gallons topped off with the torco. pump is hot wired, stock intercooler, stock valve springs, 3" thdp, kirban fuel reg., 36lb ford injectors, ramchargers dual fan ( SMALL 2ft fan in front of car during pulls and about 8/10mins of cool down ) had some blowby before i let off. ordered timing chain, valve springs. looking into some 50lb injectors. only 19.5lbs as on that pull the O2 went ( code 13 ) so there might have been more in it, but i didnt have another O2, am ordering a heated setup from Caspers. and have been looking at the ALKYCONTROL web site. we started at about 15/16lbs and added 1-11/2lbs each pull. would like to see 22 -24 lbs. but only safely, when i see/hear knock thats it. will get all this done and go back and fill ya'll in.
thanks for the kind words
