The Darkside
Heavy Metal Thunder
- May 25, 2001
I posted this in the alchy forum, but thought I'd post here too...... Anyways, I had my car dyno'd Saturday & would like some opinions on my results & if they should have been better. My combo is listed in my signaure & here's what my setting were:
Boost @25lbs
fuel pressure @ 40 line off
Smc alchy kit w/single nozzle using 100% denatured
turn on point set @15lbs
pump speed @7
Dyno was done with 93 octane with the extender chip (23/31 timing)
Put new NGK UR-5'S gapped @.035 in this morning.
1st pull was 405.98 HP & torque was 416.57 lbs. My air/fuel ratio showed me running a fat @ 10 to 1. My egt gauge showed 1550 degrees. #'s were taken between 4700 & 5600 rpm's. I was definetly running rich, but my fuel pressure is already @ 40 line off.
2nd pull I left all setting the same except to set my extender chip to 4% lean @ wot, but still that only raised my air/fuel to11.75 to 1.
Any help to help me get more HP & torque? Thought about lowering fuel pressure even more or raise it to 45 & lean it out at wot using the extender chip. Maybe try more timing & boost since I saw 0 knock?
Thanks, The Darkside
Boost @25lbs
pump speed @7
