SignUp Now!That wont be a problem, here's the dyno control room.the exit on the downpipe worked out kind bad for ya I see. Killer setup
It may surprise me, more so, it will be weeding out all the gray areas. Whats really cool is we can run an engine 24/7 and control water ,oil and inlet air temps.Cool! I've put a couple of Buick engines on the dyno. You may be suprised where peak hp comes in at.
Clayton water brake, modified by Ross Engineering. Capable of 2500 HPGood luck with the dyno testing. Your engine looks great.
What kind of a dyno is that?
Looks awesome. All the best with it.
Isn't the o2 placement too far down the downpipe for a proper reading? I thought they always had to be between 12 to 14 inches after the turbo. Might want to look into that.
Dual knock sensors show no detonation, just the headers glowing red.What was with the sparks in the header at the end of the run? Detonation?
