forcefed3.8's
Buckeye Bullet
- May 26, 2002
Here is a 23 to 24psi pull from the dyno tune at Buschur's.
SignUp Now!It was an old cast wheel 76mm hpq with a Precision .85 Buick housing. The 76mm wheel was overkill. The cast 70 and billet 71 and 67 have proven to make over 1000hp with the right turbine.Very nice! What turbo were you running in 3 bolt t3 and what ar to run into the 8's?
forcefed3.8's said:Thanks. The issue is firing all of the E85.
1.28 AR Garrett divided housing, 224/224 hydraulic roller with solid lifters lashed .007", compression is 9.6:1. This turbo has slightly more lag than the 7668, but with the CO2 on the wastegate rather than a stock style actuator and a THDP, it hits full boost quicker. Ramping in the boost on the AMS1000 is nice too on the street.
