TT/Ameasap
The White Blur
- Jan 31, 2002
What else can go wrong? Geez!Got a bad ignition module now, but the car has been running like a scalded dog with higher timing. Pulls hard in 3rd at 17-18psi.
When you get up into the 30psi range it will probably want the 10.8 AFR (or lower) to fight knock.Back up and running again.
Beat it like a horse today in 95° temps. Blew an intercooler hose, so 4ply is on the way. Runs really well with 25° timing, 18psi and 10.8AFR's. Once I get it all tuned, Im going to lean it out to 11.3-11.5. There is a big difference in power with those AFR's.
BTW,
Boost will be going north of 20 when it gets cooler out.
Thanks for the tip Steve.When you get up into the 30psi range it will probably want the 10.8 AFR (or lower) to fight knock.
Yes I do. I started a post about that and everyone said ya don't need it.
I thought misting the air stream would helP keep thing cooler.
