BEATAV8
The Engine Whisperer
- Feb 14, 2002
that little thing in the white and blue was distracting me from the cars.....
SignUp Now!I think that car has a worp drive......11.5 @ 43PSI-
Idk what I'm gonna do about that wing. I wish it was an easy fix. I have to separate the rear deck lid from the glass, and straighten it. Hopefully it's not a major projectDave, give that car a good bath and slap that wing on. Show N Go!!!
I started with 18psi, and never touched them after that. I should've checked them after a couple passes to see how high the pressure gotWhat psi were in the Hoosiers Sunday?
I went up to 144 with my chip. That was right around 61-62% duty cycle. I don't think I'll be going any higher than that.Well, at least it's running good now. You have the best suspension set-up for your power I have ever seen on a TTA.
Took my car out today and flogged it a few times. Lowered timing a little to be safe. Logged a few clean runs without alky. I still need to send my chip back to Eric tho. I am maxed on fueling .
Anyway, set of Hoosiers is next on the list. I'm gonna give these DR's another try at 17psi this time with stock TQ arm.
Crank up that alky!Im maxed at 18-19 psi @ 154 in the chip and 47psi static pressure. Inj. DC is 64%
I have my alky at 2 just cuz I got a tiny little blip of kr early in 3rd gear. WB was reading incorrectly, so it was tough to know exactly. It was showing 9.5 afr, and lowering during the run. Nb was a little higher than .800I didnt want to rely on the alky too much. Just mist it down the track. My AFR's do get really fat spraying at 2-3 setting. What are you set at and does your AFR get a lot fatter?
AFR's seem to be a big difference from 93 octane. I was at 10.0-10.2 with alky on. Then shut it off and AFR went to 11.6-11.8
OK OK I'll get some times up today!Throw your times up Dave.
Idk I never checked it yet. Did you install your ta?I can't remember if I talked to you about pinion angle or not. I was planning on running -3....... What's yours at?
