E85 swap
captrob
Slow GN Fizz!
May 30, 2001
256
11
18
46
Keller, TX
www.captrob.com
Depends on where you are located. Still relatively sparse in the metroplex. You can find it though. Might have to travel and tank up.
iPhone apps that I use to find stations that carry E85. : E85 Prices and Alt Fuel.
TexasT
Texas, Where are you from
Sep 10, 2002
4,579
370
83
117
Texas
ihadav8.com
the only place I know of is the racetrack at cooper and Mayfield in Arlington. I am kind of planning to do an e85 conversion but a set of larger feed and return lines and a dw400 pump will go on to make it go. The guys i know who do it have the -8 feed, -6 return and the dw400 pump, and a gnecu to tune for it. So I have some saving up to do.
Bullnerd
10
0
1
Jersey
Visit site
Whats the advantage of using E85?
I'm getting back into my t-type after being away for a while and I keep seeing E85 mentioned.
I thought Ethanol was a no-no for performance cars?
TexasT
Sep 10, 2002
4,579
370
83
117
Texas
ihadav8.com
if the fuel system is setup for alcohol it is a decent fuel. It is quite corrosive. But it burns cooler than gasoline so you can run more boost. But it has fewer btu of energy so you need more of it than gasoline. Hense the need for a larger pump, this in turn requires the larger feed and so the pressure can be controlled by the pressure regulator so a larger return is also needed. This can all be added and the stock stuff left there so the car can be returned to stock in the future if that need arises. Then there is the larger injectors. And a need to control them . You can see how this spirals out of control.
ETraugott
24
9
3
32
Im no expert but the fuel itself is not really corrosive. the problem is it absorbs moisture which will cause corrosion. you usually wont have any issues as long go through the fuel often. Just dont let it sit for long periods of time.
  • Like
Reactions: 626gn
1-CLN-GN
274
11
18
I’ve been getting my E85 in Irving off Loop 12/Shady Grove and it’s been testing 85+
TexasT
Sep 10, 2002
4,579
370
83
117
Texas
ihadav8.com
what is in it that eats up the rubber parts in older carbs on outdoor power equipment? I was under the impression it was the alcohol and its properties in the gas mix.
ETraugott
24
9
3
32
yes its eats up rubber that is not rated for it but the corrosion is due to the moisture it absorbs.
  • Like
Reactions: 626gn
TexasT
Sep 10, 2002
4,579
370
83
117
Texas
ihadav8.com
either way you need a big pump(s) and the lines to move the fuel. A birdie told me he was swapping out the dw400 for a twin racetronix setup as he didn't like the look on the logs and that is a lot of pump.
Steve-M
14
4
3
32
There’s a few places I know of. Valero in oak cliff, ft worth Ave and Davis sells it. Lewisville the racetrack off 544 and sam Rayburn sells it
Top Bottom
