TurboBob said:what chip are you running........?
B
It's a chip programmed by Joe Lubrant. It's an alky chip that has 100% fuel. But I need even more fuel!
SignUp Now!TurboBob said:what chip are you running........?
B
sydwyndr said:Wouldn't a chip for a set of 50lb injector and a set of actual 72lb injectors be pretty close??
d0n_3d said:??? I think you mean it to be the other way around. You need MUCH more injector. In order to support the power I am trying to make, I will need 84 lbers just to make 700 horse to the flywheel on alcohol. (and this is at 100% DC) I would need ECM tunability to control the fuel much higher. Then I would need a fuel pump capable of supporting that power safely (not a Walbro, more like a Weldon). Then this would work perfectly...but who wants to go through all that??? I guess if your car is already set up then it would be good for ya...but I'm crossing a fine line I think.
Quiky One said:You made it sound like he would need a chip for 50's that would work for a car with 72's on e85. It is the other way around. A chip for 72's that would work for a car with 50's on e85.
HTH Jason
granatl said:I decided to try E85 today. Seems to make idle and anything under 2000 RPM rougher, but beyond that mar car seems to pull real well with it.
sydwyndr said:I thought you said you needed 25-30% more fuel than normal??
rb68rr said:Ok, so with my combo listed below, what would I have to change in order to take advantage of the E-85? R.B.
loki993 said:i think we need somebody to make an e85 chip for TRs. as for the corrosion ive seen somebody say this before. 1 it needs to come in contact with water first before it becomes corrosive. 2 its not like it will happen overnight, i think it would take a while, i would think you would probally be rebuilding themotor before you would be having corrosion problems and after that it would not be an issue.
Pablo said:yeah its alcohol, not sulfuric acid
people keep repeating the same thing but I have yet to see any data.
I want to know how long it will take before it eats through a rubber hose or a non stainless line.
Ill bet it takes longer than the engine itself is designed to last.
